using form data source (Repeating Group or Field) for combo box - InfoPath Dev
Last post 09-26-2008 07:20 AM by dlgross. 2 replies.
  • 09-12-2008 06:01 AM
    I want to use the same list of choices for multiple combo boxes on the form (InfoPath 2007). I know how I can lookup the values from a list on SharePoint but I want the form to be self contained. I see the choice for looking up the values in the Forms data source, but I can not figure out how to create a repeating group or field to implement this appoach. Could someone please point me in the right direction.
    dean
    Dean
    Charlotte, NC
  • 09-12-2008 09:42 AM In reply to
    • Patrick
      Male
    • Joined on 11-04-2007
    • Texas
    • Posts 51
    Re: using form data source (Repeating Group or Field) for combo box
    Hi Dean,
    You may be able o use a resource file that a repeating table/group can pull data from. If you create an xml file with the data in it, then you could include it in the form by attaching it as a resource file and referencing it with a secondary data source connection.  Then you can filter the values based on your needs.
    I have had success with this method in the past, and you can transfer the form outside your domain without losing functionality.  I hope this helps !
    -Patrick
    -Patrick
  • 09-26-2008 07:20 AM In reply to
    Patrick, thanks for the suggestion. What is the trick for creating the XML file in an acceptable schema. I made a simple list in Word 2007, saved it as XML, added it a resource file, but when I create the secondary connection to it  I get an Unspecfied Error.
    Dean
    Dean
    Charlotte, NC
