Allow user to add more than one choice in a choice group - InfoPath Dev
Last post 03-18-2018 05:00 AM by Sankar ns. 2 replies.
  • 03-15-2018 10:40 PM
     I created a schema which has choice group like
    Partition
       - Partition Name
       - Folder Name
       - File Name
       - Symbol Name
    After creating xsn, I found that user is allowed to insert any one of the choices. How can I modify the schema or design where the user is allowed to insert more than one choice.
    My second question: My schema has iterative choice groups, Is it possible to show or hide choices in different levels? If so how?
    Attached my xsn file
  • 03-16-2018 07:54 AM In reply to
    Re: Allow user to add more than one choice in a choice group
    I'm wondering if you have tried just starting with a blank form to design your schema? It sounds to me like you don't really want a choice group, but instead a number of repeating nodes inside a parent group.
  • 03-18-2018 05:00 AM In reply to
     I'm not sure if I have to use a choice group for my requirement. I just read about choice group which looked like the one I need
    My requirement is that, I have to create an xsn where I need to have options for the user to insert anything he needs
    example : I have a partition element under which user should be able to insert any of the below elements
     - partition(recursive)
     - folder name
     - file name
     - symbol name
    The user should be able to insert any one(or more). when I create a choice it allows me to insert only one
    Please let me know what should I use for my requirement(an example would be more helpful)?
    Thank you
