How to access image field on the Task List - InfoPath Dev
Last post 08-31-2017 04:16 PM by Hilary Stoupa. 1 replies.
  • 08-28-2017 07:49 PM
    I created a infopath form, I am trying to add the image field as a column it giving the error The select field cannot be promoted because its data type is not supported: base64Binary. How I can add the image field as a column on SharePoint view. My aim is to access the action items uploaded image on the Task List. How I can do this in SharePoint. Any idea ?
    Filed under: ,
  • 08-31-2017 04:16 PM In reply to
    Re: How to access image field on the Task List
     The only thing I can think of is to write the image off to a picture library and replace it with a link. If you are using Office 365 that gets tough, because you can't have forms with code (we make an InfoPath replacement called FormsViewer that can do this tho)...
