Dear all, good day.
Dear all, thank you in advance for your help.
What I need is to make a field that searches the last record or ID entered to be able to concatenate with a pair of strings to complete the data.
I have already done the Data Connections routine (Submit and recieve Data respectively), and it brings me the data that I request and also using the max () function, but it does not show me the number until I save the document and my field appears only until I open it to see that I send the form.
The same thing generates me when I use rules to be able to bring the data, only until I send the document.
And it is necessary that the data appear when the user is filling the form so that he can know which record is the one he is using at the moment.
I am using Infopath 2013 Designer, SharePoint Designer and I see the result in O365.
Thank you for your responses and support.
Greetings
