Hi.
I need to modify an existing sharepoint custom list to Brand up the form and include some images.
So I'm using Infopath 2010 to modify the list - although once the form opens up in Infopath I'm finding that some of
my control options are missing.
The main one being the Option Button Control.
I've found that I can input a tick box control and then change the control to an Option Button although it wont give me the
option to select the amount of Option buttons I would like (5).
Does anyone know how I can get the Control panel to be exactly the same as if I was creating the form in scratch on Infopath? Is there
something I need to switch on or activate?
Apologies if this is something simple - I've had a look on google and cant find the answer at all.
Any advice would be greatly received.
