Some Control options are missing - InfoPath Dev
Last post 01-31-2020 09:44 AM by Hilary Stoupa. 2 replies.
  • 03-04-2014 07:39 AM
    Hi. I need to modify an existing sharepoint custom list to Brand up the form and include some images. So I'm using Infopath 2010 to modify the list - although once the form opens up in Infopath I'm finding that some of my control options are missing. The main one being the Option Button Control. I've found that I can input a tick box control and then change the control to an Option Button although it wont give me the option to select the amount of Option buttons I would like (5). Does anyone know how I can get the Control panel to be exactly the same as if I was creating the form in scratch on Infopath? Is there something I need to switch on or activate? Apologies if this is something simple - I've had a look on google and cant find the answer at all. Any advice would be greatly received. Thanks
  • 01-31-2020 09:34 AM In reply to
    Re: Some Control options are missing
    Facing same/similar issue here. Created a list form from scratch but the "Option Button" is missing. It is available when I create a form as a Library form though. Anyone found a solution to this yet?
  • 01-31-2020 09:44 AM In reply to
    List forms just have a subset of controls available to library forms. You could create a library form instead of a list form and promote all the fields you need to see in the library.
