Christiaan
Hi Hilary
I am not signed into Windows 7 at all. I am signed in as the Administrator on SBS.
I already use a data sourse on the SBS machine.
I'm not sure where it is published, but it is saved to the desktop.
Hope that helps.
I did not set up any of those. I just did a standard SBS installaion, but I will look into it on Monday.
Hilary
By the way – you’d said the form works on Windows 7 – how could you not be signed in? I mean, you log onto the machine with a particular username, right?
Christiaan
Hi Hilary
Hope that helps.
Hilary
Hi - I've not use SBS 2011, but here are a few questions that may help you troubleshoot -
Are you signedd into server with the same credentials as your Windows 7 machine?
What happens if you try to design a form using the same data source on the SBS machine?
What is the published location of the form that you are opening it from?
Christiaan
I replicated the database and form on Windows 7, for my support call with James.
I did not have that issue on my Windows 7 laptop.
I do have the issue on the SBS, but the are not connected at all.
