Hi HIlary,
Thank you for the reply. No, the "Remove Code" button is disabled. I tried the instructions but while verifying/uploading it gives me error sayting that "the form template has not been correctly published to be browser-enabled. . . "
The difference I am seeing is, while publishing form, in 2nd or 3rd screen where it gives
ChkBox: Enable this form to be filled out by using a browser
What do you want to create or modify?
Option 1: Document Library
Option 2: Site Content Type (advanced)
Option 3: Administrator-approved form template (advanced)
Only option 3 is enabled, the ChkBox is checked. It was not like that before.
Any suggestion?
