Shred Question - InfoPath Dev
Shred Question
Last post 05-25-2009 08:56 AM by Jim Cantwell. 7 replies.
Page 1 of 1 (8 items)
  • 05-22-2009 01:08 AM
    • Wizard
    • Joined on 11-18-2008
    • South Africa
    • Posts 19
    Shred Question
    I have a question regarding the updating of the xml structure in InfoPath forms. Obviously there are changes made to forms as life progresses, my question is what happens with the forms that doesn’t have the updated xml elements in when QDABRA shreds them? Are they rejected?
    Example:
    Form 1 created Monday.
    Tuesday we add fields and update DAT with latest version and mapping to DB What happens with form 1 when it needs to be shredded again to DB but doesn’t have the additional elements?
    Background: We use forms services in MOSS to capture data and built a custom application that loops through SharePoint once a day to perform the shredding.
    Thanks, Neill
    Filed under:
  • 05-22-2009 07:31 AM In reply to
    Hi, Neill:
    If an existing XML doesn't have an element that you have mapped in DAT, it simply won't provide the mapped column any data. So your new column that the new field maps to will have a NULL value for the rows associated with the forms that don't have the new field.
  • 05-24-2009 12:25 AM In reply to
    • Wizard
    • South Africa
    • Posts 19
    Thanks Hilary, so it won’t simply reject the old version of the xml because of the new elements not being present?
  • 05-24-2009 09:57 AM In reply to
    It certainly shouldn't, and in my experience, doesn't...
  • 05-24-2009 10:45 PM In reply to
    • Wizard
    • South Africa
    • Posts 19
    Thats great. One last question, we are moving servers and I need to backup and restore DAT to the new server. I asked this question before and received a link but it doesnt work anymore.Any ideas?
  • 05-25-2009 03:31 AM In reply to
    We have a tool that allows you to migrate document types and documents from one instance of DBXL to another. Find it here.
  • 05-25-2009 04:30 AM In reply to
    • Wizard
    • South Africa
    • Posts 19
    Thank you. Will give it a try
  • 05-25-2009 08:56 AM In reply to
    When moving an entire DBXL installation to another server, you can follow these steps:
    1) Restore the databases QdabraDBXL and QdabraSamples to the new location (or whatever you chose to name them)
    2) Install DBXL, pointing the installation to the restored databases.
    3) Open the DBXL Administration Tool (DAT) from the new server.
    4) Edit/Save each document type you have.  This is required so all the DBXL data connections in your templates get updated to reflect the new site url.
