Repeating table and rules - InfoPath Dev
Last post 11-19-2013 06:42 AM by EricW. 0 replies.
Page 1 of 1 (1 items)
  • 11-19-2013 06:42 AM
    • EricW
    • Joined on 06-19-2012
    • Posts 5
    Hi, I have a repeating table with 6 columns. Column 5 needs to be entered by the user with two numbers like "1234567890 / 1234". The first ten digits in this field, the first number, is to be looked up in the database and retrieve an email address matched with this number. The email address is then to be put in the textbox of column 6. My first attempt was a rule on the textbox in column 5, when it changes look up the email address, but that worked only for the first line. My second attempt was a button on the form to perform the ruling, but I get the same result. The formula is: @Email[starts-with(@CostCenterID; substring(txtCostCenterGLacc; 1; 10))] So this looks in the email field of a database table where the field "CostCenterID" starts with the first 10 digits in the repeating table field "txtCostCenterGLacc". How can I make this work on all the lines in the repeating table? Either by clicking a button or (preferred) by rule on field in column 5 in the repeating table. I hope someone can help. rg. Eric
