Thanks for the reply Jimmy.
Ok I will walk you through what I am trying to achieve. Let me know if this a feasible solution
We currently have about 200 windows forms and we are trying to move to Infopath forms. As a first step for all the existing forms we have generated XML and XSL and XSD's respective to each and every from.
Now I am trying to create a Infopath form ( XSN Forms ) for each and every xml and xsd. I am thinking basically if the below two approaches will do it
1.) creating *.xsn files using the schemas. (are there any VS Tools for office solutions to do this )
2.) make a CAB file using existing XML,XSD and XSL and generating Manifest XSF file( again will have to generate this manifest programtically for repective forms).
Are any of these a feasible solution. Thanks
