Generate Unique Id based on Library ID - InfoPath Dev Sign in | Join | Help in General InfoPath (Entire Site) InfoPath Dev InfoPath Dev is dedicated to bringing you the information and tools you need to be successful in your Microsoft Office InfoPath development projects. Home Blogs Forums Photos Downloads InfoPath Dev » InfoPath » General » Generate Unique Id based on Library ID Generate Unique Id based on Library ID Last post 08-26-2008 10:34 PM by Anuma. 4 replies. Page 1 of 1 (5 items) Sort Posts: Oldest to newest Newest to oldest Previous Next 08-26-2008 05:30 AM jeeva Joined on 07-18-2008 Bangalore Posts 79 Generate Unique Id based on Library ID Reply Contact Hi,I create infopath form with multiple views.I have to give unique ID when submit the Forms based on the Sharepoint Document library ID. Filed under: infopath 2007 08-26-2008 06:48 AM In reply to swathip Joined on 10-30-2007 India Posts 487 Re: Generate Unique Id based on Library ID Mark as Not AnswerMark as Answer... Reply Contact Hi, You can use GUID value to give unique value in Infopath. Swathipwww.ggktech.com 08-26-2008 09:40 PM In reply to jeeva Joined on 07-18-2008 Bangalore Posts 79 Re: Generate Unique Id based on Library ID Mark as Not AnswerMark as Answer... Reply Contact Hi,I am new to Infopath could u explain how use GUID values. 08-26-2008 10:33 PM In reply to swathip Joined on 10-30-2007 India Posts 487 Re: Generate Unique Id based on Library ID Mark as Not AnswerMark as Answer... Reply Contact Hi, You will get the unique value using "Guid.NewGuid()" in the c# code. After getting this value, you can set this value to the field to which you want unique ID. Swathipwww.ggktech.com 08-26-2008 10:34 PM In reply to Anuma Joined on 07-20-2005 India Posts 525 Re: Generate Unique Id based on Library ID Mark as Not AnswerMark as Answer... Reply Contact Hi, Can you verify this link. http://bytelab.blogspot.com/2008/06/submit-infopath-forms-to-sharepoint.html I hope this will help you. Anuma Chinthapalli /http://www.GGKTech.com Page 1 of 1 (5 items) Copyright © 2003-2019 Qdabra Software. All rights reserved.View our Terms of Use.
