quote:
Originally posted by Greg Collins
You need to use the current() function... check out the following articles and example forms:
http://www.infopathdev.com/search.aspx?s=current()
Thanks for responding.
I spent a good portion of my time going throught these tutorials, workarounds, and examples. I only found one article that pertains to my problem, "Automatically Populate Fields from a Drop-Down Selection".
I am using the rule functions since I do not know any codes. I set up rules in my drop-down box, the individual fields, and both. Where do I set-up my rules? I get the same results no matter how I set my rules. The rule I'm using is this, InfoPath_field=Access_field[@Access_record=current()].
I have use the repeating section and the non-repeating section. I get the same results everytime.
I have to use the company's .adp Access format. The field characters are nvarchar and text. The record is the only integer field. Is this still feasible to automatically populate my fields?
