OnLoad event for date picker field - InfoPath Dev
Last post 05-21-2008 05:51 AM by mattb. 2 replies.
  • 05-20-2008 08:15 AM
    • mattb
    • Joined on 05-20-2008
    • Posts 15
    Hello, this is my first post here.  Looks like a great forum!
    I'm looking for the proper code for an OnLoad Event to blank my datepicker field called ChangeDate.  Any help would be appreciated.
  • 05-20-2008 09:58 PM In reply to
    Re: OnLoad event for date picker field
    I would go into form options.
    Open and go to rules and set your field with an action.
    You can obviously set the default. I will assume you are reset a date when a non-new form is edited.
    So you may want a conditional rule which checks this or defaults to today.
  • 05-21-2008 05:51 AM In reply to
    • mattb
    • Posts 15
    I can set a rule but there is no condition that applies when the form is opened.
     Context:
    Previously completed forms will be opened and modified.  I want the date picker (which is a required field in my form) to be cleared evert time the form is opened to avoid submission with the previous date.
    The OnLoad event script seems to be the right place but I'm not sure of the proper syntax required.
    Thank you.
