Issue with 3 and 4 character fields vs. 5 position table value - InfoPath Dev
Last post 11-28-2007 02:36 PM by Clay Fox. 1 replies.
  • 11-28-2007 11:50 AM
    Clay,
    Still having the issue where 3 and 4 character ID's are not being found unless I hit the spacebar after input into the textbox. I have included my rule and condition for a 3 character account ID entered into the form.
    Condition:
    txt_RelmNumber matches pattern Custom Pattern: AAA
    Action:
    field:   txt_RelmName
    Value:  @RELM_NME[normalize-space(@RELM_ID)=txt_RelmNumber]
    Is there anything wrong
  • 11-28-2007 02:36 PM In reply to
    Re: Issue with 3 and 4 character fields vs. 5 position table value
    If your normalize space function was working it would work for all scenarios.
    I thought you were @RELM_NME[concat(txt_RelmNumber, "  ") = @RELM_ID]
    So for thee character nubers yu were adding two spacs to the entry.
    For two spaces you would add three spaces.
    You may add a message box to verify it is detecting AAA. Then at least you know that part is working.
