Form with multiple views question. - InfoPath Dev
Last post 08-10-2007 04:20 PM by Clay Fox. 1 replies.
  • 08-10-2007 08:55 AM
    • jeagly
      Male
    • Joined on 06-04-2007
    • Huntsville
    • Posts 37
    Hi my form has multiple views and it is stored in SharePoint Form Library. The problem I am having is that multiple users can not acess the From at the same time to provide their feedback.
    What is the best way to handle something like this. Is the only way to create seperate forms for each of the different views?
    If so, how do I create a summary form that will pull the data from the other forms into one central form?
    Thanks.
    Jack Eagly
  • 08-10-2007 04:20 PM In reply to
    Re: Form with multiple views question.
    So you have multiple people trying to open the same completed form? The second user is getting a read only?
    You can use merge to aggregate multiple forms but it is limited. The best thing for reporting is to integrate your form and data with a backend database.  I would recommend you check out the Database Accelerator download, it makes integration and reporting pretty easy. Qdabra Database Accelerator Suite Version 2.0 - Developer
    Filed under:
