@ in rules? - InfoPath Dev
@ in rules?
Last post 08-20-2007 03:32 AM by Shiva. 2 replies.
  • 07-26-2007 04:58 AM
    @ in rules?
    What does the @ sign mean when you try to design actions in rules?
    For example one rule I have look like set a field's value: string = family, and it works, another action has set a field's value: @number = @value, and it does not work. So what is the @ sign?
    InfoPath 2007.
  • 07-26-2007 07:47 AM In reply to
    • romaik
    • Joined on 05-31-2007
    • Paris France
    • Posts 43
    I think @ is for attributes.
    your rule attempt to put the value of an attribute into another one.
    if one of them (or both) does not exist, it will not work properly.
    InfoPath 2003 SP2 User
  • 08-20-2007 03:32 AM In reply to
    • Shiva
    • Top 25 Contributor
    • Joined on 04-15-2005
    • India
    • Posts 694
    In InfoPath we have two field types: First is element and second one is attributes. For accessing attributes we are using ‘@’ symbol before field name.
    In rule, there is no difference to set the value for element or attribute. Can you check once your condition is correct or not and whichever you are tying to set that filed is contains value or not?
    Hope this helps you.
