New field not populating in Sharepoint - InfoPath Dev
Last post 10-04-2024 09:17 AM by Hilary Stoupa. 1 replies.
  • 09-28-2024 07:59 AM
    • Zvolta
    • Joined on 03-06-2020
    • Posts 3
    I had a textbox that had a text type as the data, but it should've been number type data. I created a new field as a Number type textbox. I have a rule that populates data in the new number type text box. but when I published the form and users inputted data it did not transfer to the SharePoint. I editted the form, renamed the fields, I changed the text type field name, and then the number type textbox field to match the old texttype it was replacing and when I published the form there was an error of duplicate columns. Unsure how to have the new text box populate into the column that was already in the sharepoint site. Thanks
  • 10-04-2024 09:17 AM In reply to
    Re: New field not populating in Sharepoint
    Hi - is this a list form, or a library form? Sometimes with promoted properties, it can be tricky to get them squared away - so if a library form, I'd probably remove both fields and republish. Check the library to be sure the columns have been removed. If they haven't and this is a new form / library, you may just want to try publishing to a new, clean library.
