Mandatory save value for infopath 2003 - InfoPath Dev
Last post 02-28-2007 09:38 PM by Kalyan Gaddam. 4 replies.
  • 02-27-2007 04:15 PM
    Hi all,
    I've developed an infopath app which hosted on the sharepoint 2k3 server and it's been working fine. when users try to save, my program will pre-fill the value for the save location and file name. Until recently some people changed the default value in the save dialog box so I wondered if it is possible which when a user use either save or save as, the program will bypass the dialog window but save the file with default information instead. So it is pretty much mandatory save value for infopath. Thanks ahead.
  • 02-27-2007 08:55 PM In reply to
    Re: Mandatory save value for infopath 2003
    Hi Welcome to the Forums,
    It is mandatory to provide a value to save infopath form. By default it will save the infopath form as Form1 and form2......
    We can also pass the name for infopath to save(uisng fields in infopath form and using GUID) instead of default one.
    I hope this will help for you.
    Thanks.
    K.Ramana Reddy / http://www.ggktech.com
    India.
  • 02-27-2007 10:07 PM In reply to
    Hello
    Please read the link below
    http://www.infopathdev.com/forums/topic.asp?TOPIC_ID=3543
    Hope this helps you
    Kalyan G Reddy
    Infopath MVP 2007 and 2008
  • 02-28-2007 03:48 PM In reply to
    Great, that works for me from Kalyan. Thanks gusy for your help.
  • 02-28-2007 09:38 PM In reply to
    Hello
    Glad that it was of help to you
    Kalyan G Reddy
