Concat URL and field data - InfoPath Dev
Last post 07-16-2014 03:52 AM by k1127152. 3 replies.
  • 07-11-2014 02:40 PM
     Hello all..First post here
    I am new to infopath and have seen a need to place completed forms into different directories or libraries.
    For example
    url +directory1
    or
    url + directory2
    In field 2 of my form I have a drop down box with 2 options.
    the options are "directory1" and "directory2"
     I am unable to get this data connection working.
    Is there a solution out there and could someone share this with me please.
     Thanks in advance
    Sam
  • 07-12-2014 07:36 PM In reply to
    Re: Concat URL and field data
    Hi Sam,
    If you have SharePoint, this is pretty easy to do by way of a workflow that copies the item and then deletes the original.
    If you don't have SharePoint, you can write some code or use qRules to dynamically change the URL on the fly. There's a free trial of the qRules plugin available on our Qdabra dot com site.
    Feel free to email us via support at qdabra dot com if you need help. qRules comes with a free hour of support.
    Best,
  • 07-13-2014 12:06 AM In reply to
     Hi Patrick
    Thanks for the reply.
    I do have sharepoint.
    It is at my work and not on my home laptop.
    Sounds like it is do able. I need to skill up on workflows.
    Do you have a suggestion for a reference source for me to complete this.
     Thanks again
    Sam
  • 07-16-2014 03:52 AM In reply to
    Maybe I misunderstand your question, but it seems to me this is very simple to do with a couple of rules
    Set up a seperate data connection for each of your libraries
    Add a button to your form and label it submit, add a couple of rules to it:
    Rule 1:
    Condition: Dropdown = option1
    action: submit using data connection 1
    rule 2:
    condition : dropdown = option 2
    action: submit using data connection 2
