Can I stop Infopath from jumping to the bottom? - InfoPath Dev
Last post 05-27-2014 05:39 AM by cafescott. 2 replies.
  • 05-20-2014 12:15 PM
    I'm revising a very long InfoPath form. InfoPath keeps on bouncing me to the bottom when I am trying to work in a specific area.  Can this behavior be turned off with an option setting?
    Thanks,
  • 05-22-2014 07:03 AM In reply to
    • RaYvA
    • Top 100 Contributor
    • Joined on 05-08-2013
    • Melbourne, Australia
    • Posts 86
    Re: Can I stop Infopath from jumping to the bottom?
     When you're in InfoPath design? If so, probably not, it's worse in SharePoint Designer, it's not that easy to determine where you are in the designers as if you were in a web page with a location tag, so, you just have to keep scrolling up and down unfortunately
  • 05-27-2014 05:39 AM In reply to
     OK, thanks for the reply (even if it is bad news).
