I've created a simple access database with the fields:
Date
Invoice No.
Qty
Description
Rate
Amount
VAT
Total
I now want to create a simple invoice form that only allows one input per field so that when the invoice is complete I can update the database with code behind a "Submit" button.
However, if I now use the database connection method I can create a form OK but the moment I try to add individual fields from the database, it always puts a repeating section in the table cell which I do not want.
Anybody any ideas at all?
Many thanks
