InfoPath Checklists - InfoPath Dev
InfoPath Checklists
Last post 05-21-2013 11:48 AM by ErnestoM. 1 replies.
  • 05-21-2013 09:01 AM
    InfoPath Checklists
    Hi there, I am trying to create a library with multiple InfoPath form templates in a SharePoint library (MOSS 2007).  Initially, I made one form with multiple sections for the various checklists.  I want to change this to have all the checklist singly and appear as a template that will drop down from the 'New' button in the library. I created two separate forms, saved them to a network location.  When I added the first one as a content type, it works great.  I select it from the New drop down option and it opens perfectly.  However, after I added my second form as a content type, when I try to open that one I get an error that "This form cannot be opened because it requires the domain permission level and it currently has restricted permission.  To fix this problem, open the form from the the location it was published to.
     I did not publish either form to the library.  I just copied the forms from my network location into the forms folder within the library.  I removed my initial form and I am still getting the same error message.  Can someone tell me what I need to change to be able to open the form in the library?
    Also, is what I am doing even possible?  Can I have multiple forms, that I turned into Content types as templates within one library?
    Thanks for any help you can give me,
    Denise
    Postal Credit Union
  • 05-21-2013 11:48 AM In reply to
     In MOSS 2007 you'll likely have to admin deploy each form in Central Admin, then add the content types to your form library. That way your form library can have more than one form associated with it.
    You'll have to go through the publishing process; there should be plenty of tutorials out there on this. Copying the forms to a network location won't work.
