I have an XML as a secondary datasource. It is populated like this:
<QueryProject>
<Projects>
<ResourceID></ResourceID>
<ActivityID></ActivityID>
<ProjectID></ProjectID>
<Comments></Comments>
<QueryDates>
<ActivityDate></ActivityDate>
<ActivityHours></ActivityHours>
</QueryDates>
<QueryDates>
</QueryDates>
</Projects>
<Projects>
<QueryDates>
</QueryDates>
<QueryDates>
</QueryDates>
</Projects>
</QueryProject>
I have a SELECT statement in my c# code which grabs the available information from the database. Now, I need to populate the correct fields. I'm not that good of a programmer but I do know the basics. Currently I have a dataset being made which is then filled and then written using an isolatedstoragefilestream. The XML is then loaded back into the DOM. I can only get the Projects to load though. How do I get all the information? Thanks for your help.
