Hi I have a main connection to a database (SQL) where i joined another table to it.
This part works fine in the repeating table.
I would like to join data from a access database to this repeating table.
This database has the material code in it which is also present in the SQL database.
my problem is that it pulls out the data from the access database
the problem is that the data from access duplicates in the rows.
An example would be this.
Material Country of origin
123 GB
456 GB
789 GB
In this case 456 should have been FR and 789 DE as an example.
i tried a lot of things but it seems that i dont get it done.
The text box from The country of origin is from the segondary connection. This one is in the repeating table from the SQL database
for the other info i am pulling this material info with a button out of SQL.
I also tried to add the data in there linking the country box to the material from the SQL database when the material from the access db is the same.
Thanks in advance for your time and help.
Sky
