How to add number of days to a date from a SharePoint List - InfoPath Dev
Last post 02-09-2011 01:21 PM by Potemkine. 1 replies.
  • 02-09-2011 06:25 AM
    Hi, I am using InfoPath 2003 and have a situation to which I need some help.  I am trying to set up a form and one of the fields is a date calculation.
     I have a DatePicker control that displays the current date.
     I have 2 two other fields.
     1 is a Subject field that is a dropdown that uses a data connection to a SharePoint list that looks like the following:
    Subject     Days
    Samples     14
    Standards    7
    Labels         7
    Projects      356
    I would like to create another field called EstimatedCompletionDate which depending on which Subject is selected, will add the number of days to the DateInitiated field.
    Does anyone have a solution for how to do this?  In desparate need of some help!
    Thank you!
  • 02-09-2011 01:21 PM In reply to
    Re: How to add number of days to a date from a SharePoint List
    Hi, I think you need to write some code to do that on InfoPath 2003. The add Day function is include since Infopath 2007.
