Repeating Table - InfoPath Dev
Repeating Table
Last post 01-27-2011 07:40 PM by Patrick Halstead. 1 replies.
  • 01-27-2011 06:49 PM
    • iokje
    • Joined on 01-14-2011
    • Posts 5
    Repeating Table
    Here I have 40 line items, so I’m using repeating table to receive all the data from SAP. So, my question right now how I want to detect each of the line item inside the workflow (Nintex Workflow).  Because of using repeating table, I just can detect only the first line item. Do you have any better idea how to do this?After that, each of the line item will route to multiple verifiers to verify.  How should I do to route each of the line item to multiple verifiers? Parallel workflow? How to do that?Thanks.
  • 01-27-2011 07:40 PM In reply to
    Hi Iokje,
    I would map the items to a SharePoint list as separate rows and run the workflows off of those. qRules provides mapping to SharePoint. It takes a few minutes to get the mapping from XML to ShP list configured but after that it's smooth sailing.
    You can reference your items in a repeating table using xpath. Just use brackets to extract the nth item. For example item[3]\field will extract the field node from the 3rd item row. You can also use count(../preceding-sibling::item)+1 to get the current number of the row you are on.
    Good luck
