Auto Check In and Out Infopath form - InfoPath Dev
Last post 11-11-2010 10:55 AM by Hilary Stoupa. 8 replies.
Page 1 of 1 (9 items)
  • 11-04-2010 04:41 PM
     I have an infopath form that is submitted to a form library. my question is that is it possible to auto checkin the form when the user clicks the submit button?
    and Auto Check Out the form when the user clicks on the InfoPath form?
  • 11-04-2010 07:32 PM In reply to
    Re: Auto Check In Infopath form
     Hi, do you have the option "Require documents to be checked out before they can be edited? " checked on the settings of your form library ?
  • 11-04-2010 07:43 PM In reply to
    I have set that to "Yes"
  • 11-05-2010 04:26 AM In reply to
    Hi, try to set it to "no" and normally your file will be check in.
  • 11-07-2010 04:40 PM In reply to
    unfortunately, it doesnt work..
     well, my form has its own submit button that has some codes in it.
    is there any other way to auto checkout/checkin my form?
    thanks
  • 11-08-2010 12:21 PM In reply to
    Ok, if you don't need the chek in check out functionnality you can disabled it.
    If you want it you can set it by codes throw Web service, I found this sample :
    public static void UpdateListItemCheckOut()
                listservice.Lists listProxy = new listservice.Lists();
                listProxy.Url = "http://SERVERURL/sites/tester1/_vti_bin/lists.asmx";
                listProxy.UseDefaultCredentials = true;
                bool success = listProxy.CheckOutFile("http://SERVERURL/sites/tester1/tester2/test.txt", "False", string.Empty);
                success = listProxy.CheckInFile("http://SERVERURL/sites/tester1/tester2/test.txt", string.Empty, "0");
  • 11-10-2010 04:29 PM In reply to
    Thanks for this.
    I dont want to disable the chek-in / check-out. i just want to automatically check out or checkin the file. or maybe if possible, redirect the user to the checkin page when the user clicks on submit button.
  • 11-10-2010 05:09 PM In reply to
     Hi, for redirect the user after the submit, this link can help you:
    http://moldenco.blogspot.com/2007/10/redirecting-after-using-infopath-form.html
  • 11-11-2010 10:55 AM In reply to
    I just blogged using SharePoint's web services for this. No code required.
