Problems with Contact Selector - InfoPath Dev
Last post 08-20-2010 06:42 AM by Selarim. 6 replies.
Page 1 of 1 (7 items)
  • 08-17-2010 11:51 AM
    • Selarim
      Male
    • Joined on 10-30-2009
    • Brazil
    • Posts 48
    Hello..
    I'm facing two problems with a contact selector control on InfoPath 2007.
    1st - I want to put only users in the control. I know this is possible on InfoPath 2010, but is there a way (or a workaround) to do that with InfoPath 2007? I Googled and Binged it, but didn't find anything.
    2nd - My save button has a conditional formatting to disable if the contact selector is blank. The problem is when I put something that is not an user (like "aaa", for example). A dialog is opened, but if I cancel it, the "aaa" does not disappear, and the save button is still enabled (the attached images will help to understand). I wish I could disable the save button if there's something in the contact selector that is not an user ("aaa"), or I want the contact selector to doesn't accept anything but users (or users/groups). Any idea?
    Any help will be greatly appreciated.
    Thanks,
    Selarim
    Filed under:
  • 08-17-2010 11:53 AM In reply to
    • Selarim
      Male
    • Brazil
    • Posts 48
     The other image.
  • 08-18-2010 07:29 AM In reply to
    • Selarim
      Male
    • Brazil
    • Posts 48
    Re: Problems with Contact Selector
    Please, I need these answers (ever the answer is "you can't do that on InfoPath 2007")..
    Thanks...
  • 08-19-2010 12:38 AM In reply to
    You can't control what is typed in the Contact Selector field. If you need that kind of control, you should look at Qdabra's Contact Selector XTP which only allows users to select valid Active Directory names.
  • 08-19-2010 12:37 PM In reply to
    • Selarim
      Male
    • Brazil
    • Posts 48
     Thank you for the answer, Patrick. But I solved the problem (with Cobb's help).
    Here's the link:
    http://social.msdn.microsoft.com/Forums/en-US/sharepointinfopath/thread/9bb66264-9f81-40ab-9639-5435ddd772c7?prof=required
    Thanks..
  • 08-19-2010 11:38 PM In reply to
    Glad to hear you got it fixed! Clayton Cobb has a good website and we have worked with him before. The contact selector has limitations but should serve most needs. Let us know if you have any further questions, or go bug Cobb! :)
  • 08-20-2010 06:42 AM In reply to
    • Selarim
      Male
    • Brazil
    • Posts 48
     Thank you, Patrick..
