Conditional Formatting - InfoPath Dev
Last post 04-27-2010 01:40 AM by Flashbag. 9 replies.
Page 1 of 1 (10 items)
  • 04-26-2010 05:27 AM
    I have a question about conditional formatting in InfoPath.
    I have a few checkboxes and what i want is that if i checked all checkboxes a sentence becomes green so you know that you checked everything.
    The problem is that i have 9 checkboxes and conditional formatting only allows 5 at a time. So what happens is is if i check the first 5 boxes the sentence become's green while 4 checkboxes are still blank.
    I already tried 2 seperate conditional formatting jobs but it didn't work.
    Someone please help me!
  • 04-26-2010 05:50 AM In reply to
    try the reverse one.
    by default have the text to be greeen and put conditional formatting
    if checkbox1 != true or checkbox2 != true  or checkbox3 != true
     set text to normal color.
    have multiple conditional formattings like the above i.e. checkbox 1- 5 in first and 6-9 in another
    Qazi Anis
    Technical Architect
    Bitwise Inc
  • 04-26-2010 06:03 AM In reply to
     I made multiple conditional formattings and the problem is when i check the first 5 checkboxes the text becomes green and if i only check 6-9 it also becomes green.
  • 04-26-2010 06:04 AM In reply to
    It seems you have done exactly opposite of what i said, can you read my above post again and try to do it again, if you are unable to do it or it does not work attach the form template, so that i can set the condition for you as soon as i get time
    Qazi Anis
    Technical Architect
    Bitwise Inc
  • 04-26-2010 11:11 PM In reply to
     Is it possible that you can make a step by step tutorial for me ?
    The form contains private information and can't be published on the internet.
    Hope you can help me.
  • 04-27-2010 12:18 AM In reply to
    check attachment. EDIT: sorry for the attachment Name, it was an honest mistake
    Qazi Anis
    Technical Architect
    Bitwise Inc
  • 04-27-2010 01:13 AM In reply to
     Haha thats okay your not the first one .
    Thanks ill have a look at it ! Thanks for your time!
  • 04-27-2010 01:22 AM In reply to
     I know what you did but i have one last question.
    How do you get true in the conditional formatting ( Screenshot added )
    Its in dutch language but waar = true
  • 04-27-2010 01:33 AM In reply to
     Nevermind got that part ^^ ill post if i have any questions :) thank you for your time ^^!
  • 04-27-2010 01:40 AM In reply to
     And it works ! thanks very much :)!
