Unable to open form after publishing - InfoPath Dev
Last post 03-11-2010 09:53 AM by zwheeler. 6 replies.
Page 1 of 1 (7 items)
  • 03-11-2010 06:38 AM
    I am new to Info and I was publishing my first form yesterday. I was publishing as a content type.
    Before publishing my form, i went  to tools >> forms option>>  make form full trust
    Then i went through the wizard. It appeared to publish correctly:
    I got a dialog box giving me: Content Type, Site,Form Template, Server Type and Security Level = FULL TRUST
    I clicked Publish - I got a dialog box stating Your Form Template Was Published Successfully
    Then i went to the library, Selected New Document and I got a dialog box with the following error message:
    The form template is trying to access files and settings on your computer. InfoPath cannot grant access to these files and settings because the form template is not fully trusted. For a form to run with full trust, it must be installed or digitally signed with a certificate.
    Can anyone tell me what I am doing wrong. If possible I can attach the steps to what i did to publish or send an email.
    Zacc
  • 03-11-2010 06:47 AM In reply to
    Re: Unable to open form after publishing
    Did you in fact sign the form with a certificate?
    Is there a particular reason your form needs to be full trust?    There is a lot you can do with just domain-level trust.
    Qdabra Software
  • 03-11-2010 07:00 AM In reply to
    I did not sign the form with a certificate. Is that required? If so, how do i sign it with a certificate? Is there a tutorial for publishing with a signed certificate. I have the book Pro InfoPath 2007 so that is what i am going by.
    Once i get the full trust working then we will try domain level.
  • 03-11-2010 07:16 AM In reply to
     You can sign the form in Form Options->Security and Trust.
    Qdabra Software
  • 03-11-2010 07:34 AM In reply to
    If i publish using a domain, do i need a certificate?
  • 03-11-2010 07:43 AM In reply to
     No, you don't.
    Qdabra Software
  • 03-11-2010 09:53 AM In reply to
    {Resolved}Re: Unable to open form after publishing
    Thank You
