Property Promotion - InfoPath Dev
Property Promotion
Last post 03-10-2010 07:27 AM by Flash408. 6 replies.
Page 1 of 1 (7 items)
  • 01-29-2010 08:51 AM
    Property Promotion
    I have a document library that uses a Administrator Approved infopath template. It has several columns that were originally published. These are all working correctly.
    I'm trying to add 2 more columns from this form into the document library. This is what I have tried so far with out success.
    1) From Root Site Column Gallery, Created 2 columns
    2) From InfoPath form, through publishing wizard, I selected the fields I wanted from the form and associated them to the 2 new columns I created.
    3) Uploaded template from Central Admin
    This did not work for this form, but this same process (minus the Central Admin step) worked for non-Administrator Approved forms.
    Any Ideas?
  • 01-31-2010 09:32 PM In reply to
    promote the fields in the form. through central admin de-activate the form to the specific site collection. the upload the form through central admin, activate it to the site collection. it should work
    Qazi Anis
    Technical Architect
    Bitwise Inc
  • 02-01-2010 07:11 AM In reply to
    Thanks. That gets the 2 new columns to show, but nothing is populated in the columns. When a new form gets submitted, the 2 new columns get populated. There are about 5000 documents already in this document library and all those are still blank.
    Any more ideas?
  • 02-01-2010 11:11 PM In reply to
    you will need to relink the documents in the document library to the new template. to relink the documents.
    -) go to document library
    -) settings -> form library settings
    -) relink documents to this library
    and select the documents to be relinked
    Qazi Anis
    Technical Architect
    Bitwise Inc
  • 02-03-2010 11:37 AM In reply to
    Is there a way to do it to all the documents? There is no "Select All" option. Don't want to spend all day clicking each check box one by one.
  • 02-03-2010 10:34 PM In reply to
    there is an easier way but i wont recommend using that, because that changes the created/by and modified/by ... any wasy the method is
    -) go to your document library
    -) actions -> open with windows explorer
    -) copy the forms to your local system
    -) delete the forms form the original folder
    -) paste the forms back and close the window
    -) refresh your page and the new property fields will contain data
    before going through these steps, do take the necessary backup ..
    Qazi Anis
    Technical Architect
    Bitwise Inc
  • 03-10-2010 07:27 AM In reply to
    Sorry for the delay, but after a few days, all the forms automatically populated the new columns. Thank you for your help!
