Fonts do not render to correct size. - InfoPath Dev
Last post 04-16-2009 11:04 PM by madhuri. 2 replies.
  • 03-06-2009 11:13 AM
    I'm seeing some strange behavior with InfoPath 2007's font rendering. If typed some samples in Times Roman and Arial at various font sizes in Infopath, and did the same in Word. The 10-point fonts match but the others do not. The infopath fonts appear much larger. Seems related to Infopath using a font "size" attribute in the saved XSL, rather than a style attribute. If I import a Word doc using the built-in importer, it works OK because the importer puts style attributes on the font tags. But if I create new paragraphs in the same document, they are done with size attributes and the fonts don't match the imported content. A screenshot is attached comparing InfoPath and Word views. - Lance
  • 04-16-2009 10:21 PM In reply to
    Re: Fonts do not render to correct size.
    This sounds like an intresting issue. What version of Internet Explorer are you currently running and is this a clean install or have you upgraded IE? Also does this only happen on that particular machine?
  • 04-16-2009 11:04 PM In reply to
    Hi
    Try by clearing the infopath cache and IE cache.
    And if you are typing the the text in text box control, then delete the control and add the control again.
    Madhuri
    http://www.ggktech.com
