Conditional Formatting - InfoPath Dev
Last post 01-15-2009 02:07 AM by Parker. 8 replies.
Page 1 of 1 (9 items)
  • 01-07-2009 02:42 AM
    • Parker
    • Joined on 01-07-2009
    • Posts 4
    I am designing forms for evaluation and I am stuck with conditinal formating.
    Is there a way to do conditional formating for multiple Controls at the same time or
    to copy the conditinal formating to other controls, without changing anything else in those controls, at once.
    Please help, I have to do conditinal formating for 500 Controls.
    Another thing that can be done is to put these controls in a different section. The only option I get for Conditional Formatting is to hide the sections. If there could be a way to disable the sections instesd of hiding it that will be helpful as well.
  • 01-07-2009 04:45 AM In reply to
    • Shiva
    • Top 25 Contributor
    • Joined on 04-15-2005
    • India
    • Posts 694
    Hello Welcome to the Forums,
    Check out this link,
    http://www.infopathdev.com/forums/t/10247.aspx
  • 01-07-2009 04:59 AM In reply to
    Add a conditional formatting for one field, copy and paste that control 500 times. Then change the binding to appropriate field. In this case the conditional formatting is applied to that control also. But make sure that the fields are in the same level.
    Another way is copy the expression of conditional formatting. Open the view.xsl and add the same conditional formatting for all fields by pasting the expression wherever it is required. In this case also the fields must be in the same level.
    Swathip
    www.ggktech.com
  • 01-07-2009 05:34 AM In reply to
    • Parker
    • Posts 4
    I have already done the binding. If I copy I will then have to bind all the controls again. That is what I am trying to avoid.
  • 01-07-2009 05:47 AM In reply to
    Hi parker,
    You can change the binding in view.xsl. It is easier than changing the binding in design mode. But be careful while changing the binding.
    Swathip
    www.ggktech.com
  • 01-14-2009 07:26 AM In reply to
    • Parker
    • Posts 4
    Hi Swathip,
    Can you please also tell me how to access view.xsl? I can t seem to be able to do that to make mass changes.
  • 01-14-2009 01:22 PM In reply to
    You'll need to save your form as source files. For IP 2007, this is available under the File menu... I believe the option in IP 2003 is worded slightly differently -- as 'Extract Form Files'. Then look in the folder you saved the source files to. Your view .xsl file may not be called view.xsl -- it may be view1.xsl, or some other name, if it is a view you added to the form.
  • 01-14-2009 09:19 PM In reply to
    Hi Parker,
    After saving the source files in to a folder you will find a view1.xsl as Hilary said. Open that file in any text editor (in Notepad). And search for the field name you have used to copy the fields and change the field name according to another field name which is there in the data source.
    Swathip
    www.ggktech.com
  • 01-15-2009 02:07 AM In reply to
    • Parker
    • Posts 4
    Thanks a lot to both of you. Instead of spending hours, it was done in mins.
