Copy a row from one repeting table to another
Last post 07-25-2008 05:04 AM by eirike. 2 replies.
  • 07-25-2008 04:15 AM
    • eirike
    • Joined on 07-25-2008
    • Posts 3
    Infopath 2007 / C# / Visual Studio
    Hi.
    I have been rewieving the post in this forum for some days now. But I still don't get it right. (I am newbie to infopath and programming.)
    My form has two repating tables(A and B). The table A(secondary datasource) is response to a call I make to a webservice. I have added a button to each row called "Add".
    Table B (main datasourse) has the same fields as the first repeating table + a button called "remove".
     I want to be able to "copy" the row from table A to table B with the "Add" Button. And remove rows from table B with the "Remove" Buttons.
     Please Help...
    Filed under: , ,
  • 07-25-2008 04:48 AM In reply to
    Re: Copy a row from one repeting table to another
    Can you go through below link
     http://www.infopathdev.com/forums/t/5373.aspx
     I think it may help you
    Thanks,
    Sandhya
  • 07-25-2008 05:04 AM In reply to
    • eirike
    • Posts 3
    Thansk for answering...
    I have tried the following with my attributes, but get an error in VS, "Error 1 The name 'XDocument' does not exist in the current context" :
    Any Ideas?
    The following was just written from memory and not tested. There might be some syntax errors in it, but it should give you a good idea of what needs to be done:
    // Get a copy of the main DOM node.
    var clone = XDocument.DOM.selectSingleNode("/my:myFields/my:PrimaryDataSource").cloneNode(true);
    // Clear the main DOM nodes.
    XDocument.DOM.selectNodes("/my:myFields/my:PrimaryDataSource").removeAll();
    // Copy nodes from 2DS to main DOM.
    var nodes = XDocument.GetDOM("SecondaryDataSource").selectNodes("/myFields/dataFields/SecondaryDataSource"); // Note: need to supply the correct namespace per element in this XPath.
    foreach(var node in nodes)
     clone.selectSingleNode("my:Field1").text = node.selectSingleNode("Field1").text;
     clone.selectSingleNode("my:Field2").text = node.selectSingleNode("Field2").text;
     clone.selectSingleNode("my:Field3").text = node.selectSingleNode("Field3").text;
     XDocument.DOM.selectSingleNode("my:myFields").appendChild(clone.cloneNode(true));
Copyright © 2003-2007 Qdabra Software. All rights reserved.
