Is there a setting to change the option buttons to horizontal?
Last post 09-23-2007 09:47 PM by Stephanie Cantwell. 1 replies.
  • 09-23-2007 02:10 PM
    Hello, brand new user and attempting to create a performance review with multiple option buttons.
    I've started out by using the performance review form and am altering to include 4 review periods. The ratings are horizontal; e.g. Competency #1 - Q1 (ratings) Q2 (ratings) Q3 (ratings) Q4 (ratings). Each time I add a new field with the option buttons, they are automatically vertical. Any ideas of how I can alter this to insert horizontally?
    Thanks,
    Kathryn
    Filed under: ,
  • 09-23-2007 09:47 PM In reply to
    Re: Is there a setting to change the option buttons to horizontal?
    Hi Kathryn,
    One suggestion is to use table layout with each column for each button.
    Hope thi helps.
    Stephanie
    Stephanie Cantwell / Test Manager
    Qdabra® Software / Streamline data gathering to turn process into knowledge
Copyright © 2003-2007 Qdabra Software. All rights reserved.
